Need help with finding the right Carb! - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-03-2013, 06:26 PM
Hey guys, I have a 1968 chevy with a 76 small block 400 board 20 over. I am running a Engine Pro CamShaft Valve Lift is Int.488 Exh. 509 with a .050 duration. As of right now I have Edelbrock 750. with an edelbrok intake. I am having problems with keeping my engine running when I put it in Drive. My RPMs are set at 1200 idle, but when I put it into drive it drops down past 300rms if not lower, and bogs down and dies. Should I drop my carb size any? Or does anyone have any other suggestions to try?
Old 05-03-2013, 06:34 PM
vinniekq2's Avatar
carb size is fine.
what is your static timing set at,,
Is this a new carb,,,,
Is the engine new,,, and anything else to work with?
Old 05-03-2013, 06:45 PM
Im not for sure what you mean on static timing, I set it TDC. Carb is old, just rebuilt motor and trying to get it running, its flooding out real bad! What other information would you need to help me.
Old 05-03-2013, 06:50 PM
I just pulled out the number 2 spark plug and it is completely soaked!
Old 05-03-2013, 07:05 PM
vinniekq2's Avatar
when you set the timing with the vacuum hose disconnected,how many šs did you advance the timing from zero?Was the carb working before? Do you have a quality ignition system? Is the camshaft long duration? Are you using headers?
NOTE: you may need new plugs
Old 05-03-2013, 07:19 PM
vinniekq2's Avatar
maybe combine both threads?
Old 05-03-2013, 08:34 PM
BOBCRMAN@aol.com's Avatar
Low manifold vac. at idle from duration of cam. Improper carb setup. The throttle plates are open too far for idle circuit function.
Old 05-03-2013, 08:56 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Done.
Lowred, please don't double post, it won't get you a faster response.
Semper Fi
The Following User Says Thank You to 68NovaSS For This Useful Post:
vinniekq2 (05-03-2013)
Old 05-03-2013, 09:29 PM
Banned
No offense but it sounds like you know just enough to really screw things up. I would either find a good mechanic that will fix your mess, or drop in a stock 350 that is in good running condition.
If you do want to fix this yourself I'm guessing it will take a greenhorn like you the better part of a week and you may spend a grand by the time your done.
Best of luck, if you're still wanting to learn what to do google is your friend but just learning what to do can take a person a while. A mechanic may get it fixed for less than a grand out the door. But it soy rs like your ignition is way off, fuel pressure may be out of line, prob needs a higher stall with that cam, and only God knows what else.
carb problems, is this the right carb, small block 400
Help Finding a Holley Carb Model Number rich144 Engine 6 02-25-2008 09:10 PM
Finding the right size carb jets. cujoe822 Engine 4 09-21-2006 07:29 AM
Finding a value spaz1 Introduce Yourself 2 04-26-2006 06:53 AM
Need help finding carb kit newchevyman Engine 7 12-03-2004 10:16 PM
I need help finding gaskets for Carter Carb.... onebadmerc Engine 2 11-29-2004 02:13 PM
