Need help finding steering wheel instalation kit for 93 saturn - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-28-2005, 05:52 PM
goth_rod87's Avatar
goth_rod87
Ok guys...im having a real hard time finding what i need and where to get it....I have a 1993 saturn sl1 that im customizing for my driver and it was wrecked before i bought it and the steering wheel airbag has been deployed my question is where can i find an aftermarket steering wheel adapter for it cause i dont really want a stock steering wheel and ive been redoing the interior in blue anyway......i want to go with the 15 in slotted blue metalflake wheel mooneyes has all i need is the adapter...if anyone knows where i can get one i would greatly,GREATLY apreciate it.....thanks,
GOTH
Old 09-28-2005, 08:19 PM
New Member
adaptor
take the wrecked steering wheel off when you pull off covering you should have metal plate bolted to column on some wheels they are welded to this plate use cut-off wheel to seperate using the cal-custom adaptor as a pattern get some3/8'' plate cut a circle to clear center bolt using custom wheel index 3 holes to attach wheel. have a certified welder weld together stock saturn piece and custom piece that should mount steering wheel. now getting the horn to work when you need it may never happen good luck
Old 09-28-2005, 08:28 PM
goth_rod87's Avatar
goth_rod87
where can i find the pattern? thanks,
GOTH
Old 09-28-2005, 09:02 PM
goth_rod87's Avatar
goth_rod87
would the grant 92 saturn kit work on a mooneyes wheel?
Problem: Steering Rack? horvath Suspension - Brakes - Steering 64 06-15-2005 08:11 PM
Dyeing factory steering wheel? Hippie Interior 3 06-02-2005 03:33 PM
To build own steering wheel or not neil madsen Interior 16 03-07-2003 01:30 AM
MustangII Steering Wheel on Chevy Column smoran Interior 2 05-05-2002 08:37 AM
59 Impala steering wheel gearhead Interior 3 03-08-2002 12:09 PM
