need help finishing 454 - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-13-2012, 11:17 AM
hey guys just need a little help getting this thing running..
i have a 454 bored .30 over all forged internals.
kieth black .25 dome pistons
lunati solid roller 663 683 lift. 246 255 @ 50
double roller chain
i just wanna get this thing going even if it wont be at its full potential. i cant afford to spend a couple grand right now and its killing me not to drive it.
so my question for you guys is what would be a semi decent head to run temporary until i save enough for some nice brodix alum heads or something.
any ideas would be appreciated.
thanks
Brandon
Old 07-13-2012, 11:44 AM
Are the pistons for open or closed chamber heads?
Old 07-13-2012, 12:26 PM
Hey im sorry how do you find that out I have all the specs for the pistons but I didn't see where it says anything like that. Thanks for your patients
Old 07-13-2012, 04:55 PM
A part number would do the trick.
Old 07-13-2012, 07:15 PM
vinniekq2's Avatar
You are using a solid roller cam so buy the good heads now.I wouldnt want to use stock valves with a roller cam and I see no reason to buy god stainless valves for stock or cheap heads. Dart 335 heads are good.
Old 07-15-2012, 05:09 PM
here is the piston part number thanks kb257
Old 07-16-2012, 08:38 AM
KB257 is a hypereutectic cast piston for use with open chamber heads. Most aftermarket heads are open chamber designs. The 781 GM head will make good power and are plentiful.
FYI, those pistons may hit when used with some aftermarket heads. You can grind the chamber a little to correct.
Old 07-16-2012, 11:35 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
double roller chain
thanks
Brandon
049 or 781 casting number heads are the "go-to" production BBC head. They need larger valves (can get by w/2.19" x 1.88") and you will need to pay attention to the deck height/gasket thickness/quench; keep the quench around 0.040" to maintain ~10:1 compression ratio or the cam will be way out of sync w/the rest of the build.
Some things to check.
454, chevy
finishing alumimnum sportcoupe Body - Exterior 0 01-19-2012 01:26 PM
finishing fiberglass matt167 Body - Exterior 4 12-22-2010 06:27 PM
finishing what you start xtotech Introduce Yourself 5 04-24-2008 02:23 AM
3m finishing products makaveli200369 Body - Exterior 2 11-20-2006 08:35 PM
Finishing Up the Pickup trees Hotrodders' Lounge 10 05-16-2003 03:07 AM
