Need help finishing tuning my engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-12-2012, 08:28 PM
Im a newbie here seaking some help. To start off i have an erratic rpm gauge needle. It goes up and down mostly during start up and sometimes when I'm cruising at a constant speed. I don't know if I might have a misfire, vacuum leak, timing is off, or maybe it's just the cam that causes this. Here are the specs on my cam http://www.compcams.com/Company/CC/c...?csid=143&sb=2
The engine barely has 50 miles since break in. Any help would be appreciated
Old 03-12-2012, 08:49 PM
DoubleVision's Avatar
When the RPM gauge is doing so, do you hear the engine doing the same?
Old 03-12-2012, 09:06 PM
Nope the engine feels like its at a constant rpm that's why i have no clue the erratic rpm needle in my gauge
Old 03-12-2012, 10:06 PM
Then the RPM Gauge has a bad ground.
New engine break-in & tuning PontiacPhil Engine 8 05-13-2010 10:14 PM
Engine tuning with BG 650V Cobra720 Engine 13 02-12-2010 06:26 PM
Tuning the engine with 1.5 & 1.6 Rockers Rustydawg Engine 23 11-04-2008 07:11 PM
help with engine tuning engineman302 Engine 8 05-01-2005 07:30 AM
engine tuning need4speed2345 Engine 11 05-11-2004 04:31 PM
