Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need help with first 383 build
Old 06-25-2012, 08:54 AM
my87Z's Avatar
my87Z my87Z is offline
Veteran/Firefighter-Paramedic
the block doesn't have to machined for a roller cam, they make retro-fit roller cams for these blocks, typically the only adjustments that are needed to be made are in the cam button/timing cover area.
yes you can absoutley use the 650DP on the street, I like the DP's. I just recomend the vaccum secondary carb because it will be easier to maintain for street use. I use a modified 750 double pumper on my street/strip car.
