Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need help with first 383 build
Old 06-25-2012, 08:30 PM
Silver Surfer's Avatar
Silver Surfer Silver Surfer is offline
More machine than man
Last journal entry: bwaahhaahahaaahhaa
Here are the numbers from Desktop Dyno 2003. There was not a supplied file for this cam, nor does it seem that Lunati publishes their valve timings like Comp Cams does. I figure this cam is pretty comparable to the Comp Camps XE268 cam so I started with that and edited the few known values that are published for this cam.
You are looking at
365 HP @ 5,000 RPM
425 ft/lbs @ 4,000 RPM
