Originally Posted by seanphelps321
Yes. I knew there are a bunch of clearance issues with strokers. I had an idea that there could be cam clearance problems as well. Thanks for reminding me of that. I'll have to keep that in mind.
You won't run into any problems with rod-to-cam clearance if you run an I-beam rod. Only big H-beams present a problem, and even then, they only get close when the lobe lift is over .400". I have a 4" stroke crank in my motor and run I-beams. I have a smaller base circle cam to compensate for this. ARP makes rod bolts with tiny 12-point heads that allow a little more clearance as well.
