Now if I go with those RHS's will I need a different intake than the one I posted? I posted an Edelbrock 7516 performer RPM air gap. But it's designed to fit vortechs. Does that matter? Also about the distributor, I don't really know anything about picking the right one. You said HEI. But what about trigger style, advance type, or computer control compatible? What should I look for in those areas? And I'm sure the gear material matters, but with that I'd need to know the material of the cam, right? EDIT: And yes, I'm on a budget. But I'm actually using this summer to build the engine, get the tranny and all the stuff needed for that, and the rear end and all that I need for that. I'm planning on doing the whole swap at either spring of next year or beginning of summer of next year so I can use the whole summer to make sure everything runs right and break it in. So I don't know my full budget yet, but it's definitely enough to get what we've been talking about. But yes, if I could afford heads like AFRs or the like, I'd definitely go that route. Last edited by seanphelps321; 07-02-2012 at 02:20 PM. |
On the stroker's cam profile is important! whether the lift is produced with a low heal (the lowest part of the lobe) or a high toe (the highest part of the lobe) The reason for this is because the rod caps come into close proximity (on longer stroke cranks) with the cam lobes and even hit the lobes on high lift cams and machining is necessary to achieve clearances sometimes negating the use of larger cams! You probably already know this and researched it! But sometimes cams are suggested because of this reason! So I thought Id mention it!
Jester |
You won't run into any problems with rod-to-cam clearance if you run an I-beam rod. Only big H-beams present a problem, and even then, they only get close when the lobe lift is over .400". I have a 4" stroke crank in my motor and run I-beams. I have a smaller base circle cam to compensate for this. ARP makes rod bolts with tiny 12-point heads that allow a little more clearance as well.
"Not sure where you get this 7.625" information, but both of my LT1 cars came with a 7.5". EVERY LS1 car came with a 7.5 as well. I'm guessing that you are thinking of the oddball Borg-Warner rear that came in a few 3rd gens. Either way both are weak. Possibly with street tires, they will last a long time, but NO WAY at the track or street with a decent drag radial or a sticky DOT tire. Not a chance in hell. My friend grenaded his 10-bolt with a bone-stock LT1 car with a t56 and a set of BFG drag radials."
I'm sorry but you are wrong, in 1989 when they switched to the 28 spline axles they also switched to a 7.625" 10 bolt rear end. the Borg-Warner 9-bolt Australian based rear end and is pretty rare. As of 1989 all car and small truck (S-10) 10 bolt rear ends were the 7.625 rear end. if you dont believe me then look it up. as for my old 355 set up, yes i ran it at the track with p275/65R15 M/t drag radials and i had the car running 12.80's. these rear ends are a weak link but there are plenty of people out there running low 11's and even 10's with these rear ends still in there car. I've seen it and so have you, you just didn't know it. While you are doing a search on the whole 7.625" rear end. do a search on how strong you can make them and how fast people are going in them. you could also ask Fbird-88 on here, i know that i have heard him talk about using the rear end as well while pushing a pretty fair amount of power. "I could piece something together for not much more $$$ and make it much more enjoyable. IMHO vortec heads do not belong on anything over 355 cubes. They simply don't have the ability to feed it correctly. A 355 with a head flowing over 250 will crap all over a 383 on vortec heads. It would cost a lot less too being able to keep the rods, and crank and not needing as much machining. He's going to run a 650 dbl pumper which can support 450+hp, and an Edelbrock Performer RPM intake which can go well over 500hp, and then crutch the build with some tiny heads trying to feed 383 cubes." unless you are going with used alm heads then you aren't going to get away with less than 1000-1250.00, and then to run a hyd roller cam set up will cost you 250-300 for the cam, an additial 100 over the base price for the springs, and then suposing he does not have a roller block as he mentioned, another 300 for the lifters, then another 30-50 for the bronze distributor gear for a total of 1700-2000.00, where as the RHS heads are 800.00 and a set of hyd flat tappet cam and lifters is around 200.00 for a total of 1000.00 I dont know where you get off thinking that i am recomeding the vortec heads to him when i was recomending the RHS pro action 180cc heads and yes these heads flow 258cfm @ .500", it has been independtly flow tested and published. here are their complete numbers: RHS 180 pro action heads: .100-74/58 .200-151/101 .300-207/157 .400-243/177 .500-258/186 .600-263/190 to put this into perspective here are the numbers for the out of box Brodix IK200 alm heads: .100-not listed .200-123/100 .300-181/145 .400-230/164 .500-253/171 .600-261/176 As per science, if something is able to produce the same or a greater amout of flow/air with a smaller diameter tube/runner then the air traveling in the tube/runner will have greater speed/velocity. the whole point of picking a street head is to find a head that flows as much air as possible within the lift range that you will be using while using the smallest runner possible as to creat greater velocity at the lower ranges of the lift where the motor/valves will spend the majority of their time. "The cooling of the engine is a benefit but the main thing is the ability to up the compression ratio and not detonate. That is something that is FREE that cannot be ignored. Put an iron head on a 383 and run it at 11.5-1 and try to run pump gas. You will have to tune it pig rich and take timing out." This does not always work, take my motor for example, i am running 11.2-.3:1 with a 106LSA cam that has an early intake closure, my dynamic compression ratio is well into the mid 9:1's and no i can not run on only pump gas when i drive on the street i have to run 1gal of 110 for every 2gal of 91-93octane. now sure i could tune it and advance the timing so far that i could run on pump gas but i would also loose around 10% or my power getting there. |
@ Joelster
I figure i can get to the bottom of what we should be aiming to recomend here by simply asking: To the OP, do you want a motor that will be in the 400-425hp range or do you want a motor that will be in the 500hp range. as with each range our recomendation will be different. |
Now with the RHS Pro Action heads, I will probably need a different intake, correct? The edelbrock 7516 said it's made to fit Vortechs/E-Tec. It looks like the Pro Torkers from RHS are Vortech style, but looking at the one's you recommended, I'll probably need something like this? Edelbrock 7501 - Edelbrock Performer RPM Air-Gap Intake Manifolds - Overview - SummitRacing.com It says stock configuration. I'll tried looking it up for these heads, but didn't see it. |
yes, you will need a different intake manifold. my advise would be to sell the vortec style one on either ebay or craigslist. they normally sell pretty easy.
then look on ebay or craigslist for a used performer rpm intake like this one EDELBROCK INTAKE MANIFOLD SBC CHEVY 305 327 350 400 V8 PERFORMER RPM 7101 | eBay in IMHO stay away from the air-gap intakes, do a search on this forum about them and then form your own opinion is what i would suggest. you also mentioned not knowing what to do for a distributor, here White Performance Detail Description you dont have to get the clear one, they also have them in red, black, and i think blue. and as i mentioned i would not go with the 650DP carb, it will work yes, but i dont think that mechanical secondaries is what you are looking for. i think that this carb would better suit your needs and this carb is pretty much one of if not the most popular carb that Holley ever made. they have a very good reputation for being quality. I have used 3 so far with absolutley no problems. but as with all carbs you may have to tune it once you acutally get everything put together so it suits your motor. there may be some that claim to be but not many (if any) carbs are "plug and play". Holley 3310-2, 750cfm vacuum secondary carburetor | eBay with the howards cam i recomended, the RHS heads, 3310 750 carb, HEI distributor, the 9.6:1 that the 64cc chambers and 18cc dished pistons will give you, and all tuned correctly is the recipe for a 425hp/450tq 383 (385 in your case) motor. now be sure to look up quench/squish before you buy a set of head gaskets so that you get your quench @ around .040-.046". with these 3rd gen f-bodies you will need to do some work to the suspenion and the rear to get it to hold this kind of power. I would either recomend you get a set of moser or strange axles, a better aftermarket carrier, and some stronger aftermarket rear gears. all of this will cost you around 1000.00 here: UMI Performance 2205-B - UMI Performance Transmission Mounted Torque Arms - Overview - SummitRacing.com UMI Performance 2019-B - UMI Performance Single Adjustable Panhard Bars - Overview - SummitRacing.com these served me well when i had my 355 Lakewood Suspension 21700 - Lakewood Traction Action Lift Bar Kits - Overview - SummitRacing.com Competition Engineering C3046 - Competition Engineering Weld-On Subframe Connectors - Overview - SummitRacing.com and then i would recomend these for the rear end Summit Racing SUM-700118 - Summit Racing® Direct Fit Axle Shafts - Overview - SummitRacing.com Auburn Gear Inc 542046 - Auburn Gear Pro Series Differentials - Overview - SummitRacing.com Summit Racing SUM-741011 - Summit Racing Street & Strip® Ring and Pinion Sets - Overview - SummitRacing.com you will spend some money but you have to pay to play, when i put my 385 in my camaro (under the old set up which made 500hp/490tq) I grenaded my rearend within 3 weeks, and that was with street tires, and only giving it about 1/3-1/2 throttle. I looked into fabricating in a 9" ford rearend but once i looked into the Moser 12 bolt direct replacement rearends i found the 9" rearend was going to be more of a hassle since i already had all the suspension parts i wanted and they would bolt up to the new Moser 12 bolt rather easily where as with the 9" is was going to require a good amount of work. good luck, i hope that all the $$$ signs you just saw that you will likely need to have a stable car didn't scare you off. take your time, do it right, and in the end you will love what you end up with. |
| The Following User Says Thank You to my87Z For This Useful Post: | ||
seanphelps321 (07-03-2012) | ||
7.5- 7.625, you are talking about a ring gear .125" bigger. WOWSER, not going to make much of a difference. Yes, I have seen them last, with upgraded axles, posi's, girdles, covers, and then they are $1200 10-bolts, that still can't handle the power of a 12-bolt, or a 9" or a Dana. The ring gears are simply too small, no way around that. A 12-bolt has an 8.75" ring gear a 9-inch has a 9", and a Dana has a 9.75". They are like watching a porcupine play with a balloon. Hit them hard enough and they will pop. No SERIOUS enthusiast would stick with a failure prone part. Run a street tire with an auto trans and they will last a long time. Put a sticky tire on and you are playing with fire. Quote:
"Hrmm, that's funny, because 93 pump is all I run. My quench is .040, static is 11.77-1. My dynamic is right around 9.3-1 as well. My car only runs mid 10's at 130 though. I'm headed to the track saturday shooting for some 10.3's hopefully 10.2's at 131-132ish. But what do I know. I would say you probably have a tuning issue, too much timing, too lean or have WAY too hot of a plug to not be able to run pump. I know guys with 12.4-1 static engines with milder cams than mine that run pump and also run 10's. A bone-stock LT4 engine had 10.8-1 compression and a cam with hardly any overlap. Care to guess what the dynamic is on that motor? Cam has 203/210 duration, intake valve closes 31 degrees ABDC. OOps, it has 10.29 dynamic. Those cars run on 91 octane as recommended by GM. Putting your car as an example doesn't mean you are right."
Acutally my motor was tuned while on an engine dyno, not in my backyard. If i wanted to change the tune then yes i could run on pump gas, but since i said it was tuned on a dyno i have seen first hand exactly what my motor wants and likes, we went through multiple combinations, between different carbs, intakes, timing... The setting we stuck with was the one that ran the most consistant over multiple pulls. if you would actually read my posts to this guy, you would see that i am not telling him that this rear is strong, i have flat told him that it is the WEAK point in the build. Yes the ring gear is small is weak but a softer aftermarket ring gear can handle 400hp. i have offered him some ideas that will help make it a bit stronger. WHAT HAVE YOU HONESTLY CONTRIBUTED TO THIS THREAD BESIDES ATTEMP TO ATTACK ME as the OP has blatently stated, he is looking for 400hp, can you, me, and 500,000 other people tell him how to build way more than 400hp out of a 383, DAH but that is not what he has stated that HE WANTS To the OP, I hope that is "bickering" back and forth between Joelster and I hasn't put a bad taste in your mouth about this site. I certainly hope that you continue to ask questions when the arrise. and I certainly hope that the advise you get is ment for what you are looking to do, not someone elses idea of fun.
. How about oxygenated fuel like Q16? Will it run better with that? No s**t it dynoed better when you boosting the octane and added timing. You tried telling him this:Quote:
You are defending the 7.625 saying how much better it is than a 7.5 when both are weak and prone to failure. That is very misleading to someone looking for info. I sold my stock rear with Richmond 3.73's to a friend of mine and he popped it at the track running 7.9's in the 1/8th. Richmonds are softer than stock. 10-bolts from 3rd and 4th gens are garbage for anything except cruising. I offered solid info in post #13, then you countered in post #14 puffing your chest about your 11 second 3rd gen. Who attacked who? Here's what I posted, pay attention: "If it's an '87+ block it should be a roller block. That would be a big plus. " "They will have to clearance the sides for the stroker crankshaft. Down by the oil pan gasket." "Iron heads will be cheap, but Vortec heads flow roughly 220cfm give or take a little, and will be adequate for a 383cube engine. I would put an aluminum head with a minimum of 195cc port that flows minimum of 250cfm. Something like this will do:" "Excellent intake, can't go wrong with that. " "It's better to buy everything as one package to save a few bucks. Try ohiocrank.com to see what packages they offer. Their cranks are made in the USA." "With an aluminum head you can go much higher on the compression than that and sacrifice virtually nothing. I run 11.77-1 and run pump 93. It will run on 91 octane but I don't push it when I run it on that. Personally I would shoot for 10.5-1 to play it safe and still make power." "That cam is very mild for a 383. Your hp goals are very low and I'm sure you'd probably hit them or be close with the parts you pick, but next year you may want more power. Just trying to save you on a teardown for next year!" This is another thing I posted: Quote:
You act like I'm trying to change his whole build. I'm just offering advice from seeing a year or 2 down the road. I think he will want more power. |
@ Joelster
@ The OP, i'm sorry that we've hijacked your thread man, i hope that you still got some valuable info between it all. feel free to ask questions and continue searching on this site as it is full of great informations and plenty of great people willing to help you.
| Tags |
| 383, chevy |
| whats better 400 crank or a 383 crank in a 350 sbc when trying to build a 383? | onlychevy | Hotrodding Basics | 14 | 12-28-2012 07:27 AM |
| Another 383 build | MUD CHILD | Engine | 24 | 06-12-2010 09:22 PM |
| 383 build | beachbum | Engine | 1 | 03-01-2010 11:38 AM |
| Here's where I'm at with my 383 build | Malibu73 | Engine | 17 | 12-06-2009 08:56 PM |
| want to build a 383 | bill4 | Engine | 20 | 08-15-2009 09:21 AM |
