Need help fitting a '33 ford hood - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-08-2008, 04:28 PM
RodFather's Avatar
I smell like a hotrod!
Last journal entry: windshield
I have a 33 ford coupe (fiberglass), and a rootlieb hood (metal). I'm trying to fit the hood and hood sides, but it seems that the radiator is not allowing the grille shell to push back far enough to meet the hood top. I have the radiator as far back as possible but I'm still way off. I've tried to lean the radiator back, but the lower hose hits the crossmember. Any suggestions?
ID:	30489   Click image for larger version
ID:	30490   Click image for larger version
Old 06-12-2008, 03:19 PM
fitting hood
RodFather,
I can't help you directly, but maybe send you to another site that may be able to guide you some. Over on the Project 33 website (www.project33.com) Scooter (car owner) detailed the assembly of a 33. From what I remember, he had several articles on fitting the hood. He has the car assembly broken down into Chassis, Body, etc so its fairly easy to navigate. If all else fails, post on his site - now that his car is done, he may be able to help.
Good Luck,
Mike.
Early Ford Spindles fitting early Ford axles pasadenahotrod Suspension - Brakes - Steering 3 08-14-2012 07:20 PM
aligning hood gto_ron Body - Exterior 8 03-25-2009 06:22 PM
1964 Impala SS Hood Adjustment 64Joker Body - Exterior 4 04-13-2008 09:11 PM
attaching 36 ford hood tops walrus Body - Exterior 1 09-11-2006 03:08 PM
331 Hemi in '33 Ford HemiFred Body - Exterior 1 01-03-2002 02:09 AM
