Need help flange tool/lap welds &cutting straight panels. - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-01-2013, 10:47 AM
Banned
Originally Posted by tech69 View Post
I think it depends on the situation. if it's a big complicated piece than a template is a way to go. If it's just a small patch you cut it out, file the edges, then use a sharpie to trace it. Thing is, not all patches are gonna come out nicely in one piece.
So that brings me to another option...just laying metal on top and scribing around the metal. This way always leaves a perfect fit and worked well for me the last time I used it, which was on a 55 rocker. The shape would be a little bit of work to do yourself so I just laid the piece on top, used a forgiving and soft hammer face to shape it into the old, then scribed and cut it out. it was a piece of cake. Those are my three main go to's. It makes it easy, but yeah, a template works well.
isn't placing the new metal over the old and scribing, making use of a template?
  #17 (permalink)
Old 05-01-2013, 11:00 AM
cutthroatkid's Avatar
two cups of tea
Last wiki edit: Need more horsepower for my 305 Last photo:
Wiki Edits: 2
Thanks all for all of the wonderful info.I've been doing butt welds in for awhile,cab corneres,rockeres etc.I think I'm gonna buy tht flange&punch tool.
  #18 (permalink)
Old 05-01-2013, 11:35 AM
put up or shut up
yeah, minus the marker and soda can boxes.
  #19 (permalink)
Old 05-02-2013, 06:05 AM
deadbodyman's Avatar
Wiki Edits: 11
There's three flange tools to get .The air flanger/punch, The hand flanger made from a pair of vice grips, these are great for straight stuff but what about flanging a curved surface,say a 55-57 headlight bucket or something similar?
for that theres a special flanger that has two wheels and you turn it with a ratchet wrench kinda like a can opener works the round wheels wont flatten the curve and you can also have round corners...if using a ratchet takes to long you can use an air ratchet to speed things up.
Everyones heard of the old saying "measure twice cut once"
my saying is "dont measure unless you have too"...
I'll show you some of my tricks (when I have more time) for getting perfect fitting patches without any measuring at all, its simple and FAST but most important a perfect fit every time...You WILL need a sharpie.....
  #20 (permalink)
Old 05-02-2013, 08:21 AM
put up or shut up
got a link to one of those flangers? I'm interested.
  #21 (permalink)
Old 05-04-2013, 09:49 AM
BigMo's Avatar
several companies make the flangers......Eastman, TIP, Northern, almost any metal working or repair supplier with have these.....Ive used them extensively over the years and IMHO its the way to go when needing strength at the seam.....Im pretty good at the butt welding gig now using a Tig torch to lay nice flat low temp hits
  #22 (permalink)
Old 05-04-2013, 09:50 AM
BigMo's Avatar
Oh crap.....EastWOOD, sorry, fingers goin too fast.....
  #23 (permalink)
Old 05-04-2013, 11:02 AM
two cups of tea
Wiki Edits: 2
Thanks I always butt weld but it seems like it has its place.I first noticed em@harbor freight then eastwood &eastwood&hf stuff seems to be the exact same tools just with a diffrent label.Anyways ill grab one of each that they have
  #24 (permalink)
Old 05-08-2013, 12:28 AM
two cups of tea
Wiki Edits: 2
thanks all I really do appreciate all of your fellas help.
  #25 (permalink)
Old 05-08-2013, 08:14 AM
Harbor freight has VERY few quality tools made by quality manufacturers like Eastwood would have. I have bought a lot of these sort of tools from Eastwood and they were all high quality. I think the ratio is exactly flip flop with the two. About 80-90% of Eastwood is high quality with 10-20 being poor, Harbor freight is flipped with the 80-90 being poor. They sell COPIES of quality tools, made poorly is generally what I have found. I seriously doubt that any tool is the same as found elsewhere with simply a different name on it, it is a cheap copy of that other one, that's all.
Every time I post this opinion I get a bunch of people telling me I am wrong but then post their opinion and it's the same as mine! Yes I have bought a few that performed well for what I wanted, my air stapler that I bought to do my convertible top, it performed perfectly and I saved a lot of money. On the flip side the "impact" sockets I bought were absolutely worthless. I don't buy much there because what I see is junk, so I can't do a review on the junk I didn't buy. I say spend the money on quality tools that you have any idea you will be using for years, or that you want to perform at a high level, it's money well spent.
  #26 (permalink)
Old 05-08-2013, 12:44 PM
put up or shut up
i think the harbor freight flanger is an ok tool. the hole puncher hole is just too darn small and doesn't let you set the hole deep enough into the panel, but you can fix that with a cutt off wheel and grinding away some metal, and it's harbor freight so who cares. i'd recommend the harbor freight flanger, it's a decent tool. if you don't do this everyday why spend on pricey tools? i wouldn't.
  #27 (permalink)
Old 05-09-2013, 06:16 AM
Wiki Edits: 11
The HF Flanger /punch is pretty decient ,I've been using my for a few years although the little pin that holds the handle on kept falling out an the handle would fall off, when I got tired enough of that I simply welded a tiny bead at both ends of the pin and it never gave me another moment of trouble...
Tech,the punch hole is the same size on all these flanger tools it is too small for a good plug weld ,a simple way to remidy this is punch two holes overlapping each other so it looks like an 8 insted of a o ......works great....
how far apart/how many plug welds should be on the bottom flange of this? matts37chev Body - Exterior 8 01-09-2012 08:17 AM
flange tool mitmaks Garage - Tools 5 05-20-2010 08:25 PM
flange tool mitmaks Body - Exterior 20 04-15-2010 10:10 AM
flange tool and bushing tool pittbull7934 Garage - Tools 14 07-09-2009 06:50 PM
Sealing Around Lap Welds xhp734 Body - Exterior 3 08-21-2007 05:59 AM
