need help founding out what small block i have - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-19-2010, 09:00 PM
i have the small block in an 84' s-10 i thought the block code read 8970010 but i was told it was a 3at the beginning not an 8 the code on the intake is 14057053 can anyone help me with this question ?
Old 04-19-2010, 09:15 PM
ericnova72's Avatar
More for Less Racer
3970010 is a common 4" bore block, used to make 302(rarely, 1969), 327(1968-69) and 350 engines. Most are 350's, if after 1969 it is definately a 350.
www.mortec.com for casting number decoding, block date code will narrow it down.
Old 04-20-2010, 07:39 AM
XNTRCI-T's Avatar
AKA Lee in KC
Look at the block right in front of the passenger-side cylinder head. There should be a machined pad there (may be hidden by an accessory, like a/c pump or smog pump). There should be an alpha-numeric code there (if the block hasn't been decked). There should be a letter, four numbers, then three letters... X###XXX. Post that code here and we'll look it up for you, or you can go to NastyZ28.com or ChevyMania.com and look it up yourself.
Old 04-20-2010, 07:57 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The intake is an aluminum 4-bbl Q-jet used from roughly '78-'85. Means there's a decent chance the engine is a 350 from '78-'79 or so- but a lot of parts swapping could have happened in the mean time.
The date code and/or the VIN suffix could tie it down closer.
big block or small block chevy 69YENKONOVA Engine 81 05-13-2010 07:26 AM
'57 Chevy Small block swap Unkie Hotrodding Basics 5 10-10-2008 11:48 PM
how strong is a 350 small block ChevyVan Engine 18 01-04-2007 11:27 PM
hv big block pump for small block roy383ci Engine 9 05-24-2006 06:52 AM
big block or small block ford? stangfiend Engine 3 12-10-2002 09:55 AM
