Need help with front suspension/ride height - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-16-2012, 09:15 PM
ok its a 70 nova with front disc breaks, new coil springs and leaf springs. the conversion was done by the previous owner, the passenger side rear sits about 1" higher than the driver side and the front passenger side sits well over 1 5/8" inches higher. i have'nt pulled the coil yet to make sure its seated properly but assuming it is what next? i measured the lower arms from the ground up to the closet point and compared, the drivers side is just over 5/8" lower than the passenger side. i have had no problems with cut springs in the past so if i cant figure this out im considering cutting 1 full coil to level her out. im sure once the front comes down the back will follow. any thoughts??
Old 08-16-2012, 09:38 PM
Wiki Edits: 27
teeter totter ?
Rear springs-shocks-sway bar will affect the front, check all four corners before cutting.
Old 08-16-2012, 11:54 PM
yeah i have checked them all, all brand new and seam to be correct, there isnt a sway bar, im wondering if the frame is just bent? its like it was a track car or something?
Old 08-17-2012, 07:19 AM
Last journal entry: Still running strong
Check the casting numbers on the spindles,they should be the same except some of then have a L & R for what side they go on and some dont.Another thing to look at is the size of the gap between the bottom a-arm an the bottom part of the spindle where the ball joint is,it should be the same.Look at the upper a-arm gap to.Why I say this is because on my Camaro after I compleatly replaced all ball joints,bushings,springs and new tube upper a-arms their was 1 in. differance between each side,their were two differant spindles on it.I bought new bearings an they went on fine on one side and the other side no go.And I couldnt figure out why the gap between the lower a-arm and the spindle was differant from the other side.This is just a quick look an see,might save you from a big F-ING problem like I had.
Old 08-17-2012, 08:40 AM
i'll check the spindles tonight, thanks. would that cause almost a 2" difference between fender sides?
Old 08-17-2012, 09:03 AM
are spindles part of that disc brake kit that was put on there?
Old 08-17-2012, 12:50 PM
Wiki Edits: 27
bad frames
there were quite a few Nova's about those years that dog walked, drove a bit sideways brand new from the factory
ride height? BigBlockT General Rodding Tech 2 01-26-2009 03:11 PM
Air Suspension Ride Height? 71gtx Suspension - Brakes - Steering 1 06-23-2008 12:43 PM
setting ride height for suspension swap pigmechanic Hotrodding Basics 3 12-21-2006 10:25 PM
56 Chevy Qa1 Suspension Ride Height Question bob barker Suspension - Brakes - Steering 1 02-08-2006 05:06 PM
Ride height 47fleetline Suspension - Brakes - Steering 1 11-05-2005 07:25 AM
