Need help with fuel gauge on chevy truck? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-15-2011, 11:15 AM
sence I fixed the wires that was causing my fuel pump fuse to blow, my fuel gauge is reading 3/4 fuel at times and drops to 1/4 at times. Before it was stuck at 1/2 full all the time. when i shut of the engine, it will stay were ever it is, even turning the key on want make it move. was wondering whats the correct way to check it both the gauge and the gas sending unit. Thanks for all the help,and advice.
Old 12-15-2011, 03:37 PM
sqzbox's Avatar
My pipes are my music
Same short that kept blowing the fuse for the pump might have shorted a couple of areas in the sending unit or even the gauge itself. I'm betting the sending unit. If it's not on full when you fill it up that's the first thing I would do is get another sending unit. Be sure if you do, the O ring is included, their hard to find out side of a kit or new tank. Sometimes you can re-use them if the come out in good shape and cleaned real well with a coat of Vaseline.
Old 12-15-2011, 04:32 PM
EOD Guy's Avatar
Before you go buy a new sending unit......... remove the tank and see if the old one is junked up. You will need the new gasket to reinstall it in the tank etc...... once you get it out you might be able to re-calibrate the arm....... or your wire repair might have cold connections.
Old 12-16-2011, 07:00 AM
how do i recalibrate it? and all the wires have good connections.
Old 12-16-2011, 04:21 PM
EOD Guy's Avatar
After you get it out of the tank, you would move the float/arm throughout it's full range of motion and watch the gauge ...... if you get full movement on the gauge, your sender works and you might be able to bend the arm to indicate a full tank on the gauge. If the gauge doesn't go full range..... it's prob the snding unit.
Old 12-16-2011, 04:56 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
you in tank unit will have 4 wires one grey,that is power to the fuel pump
The purple is the fuel gauge.The other 2 are black and they are both ground.
If you tap into the purple and touch it to ground with the key on, the fuel gauge should go to Empty.If not then the gauge is messed up.If you completly unhook the purple one the gauge will read over the top of full.If not the gauge is mesed up. If the gauge works as described here then the sender is wiped.
Old 12-17-2011, 10:00 AM
T-bucket23's Avatar
Wiki Edits: 26
bad ground for the sender is the most likely cause expecially where you had pinched wires.
Chet
1990 Chevy Fuel Gauge pemdj Hotrodding Basics 1 07-26-2011 04:26 AM
52 Chevy Truck Fuel Guage jjam123 Electrical 4 12-05-2010 01:07 PM
'98 Chevy Malibu fuel and temp gauge no worky C-10 Electrical 0 03-21-2009 09:35 PM
51 chevy truck gas gauge not working new_rat_rodder Electrical 7 02-06-2009 12:20 AM
51 chevy truck gas gauge new_rat_rodder Electrical 3 07-15-2008 06:49 AM
