I recently purchased a brand new distributer for my engine wich is the 300hp crate 360 magnum from mopar. I purchased my distributer from don at fbo systems and he told me i needed to run my vaccum advance off of manifold vaccum... So i did as he instructed set my initial timing at 14 degrees wich lands my total timing at 32 degrees and my vaccum advance adds an additional 14 degrees of timing at an idle.
Here is my problem... I am getting a faint popping and putting noise from my exhaust while the engine is at an idle and the carburetor i am running is the edelbrock performer 600cfm manual choke carb and i have adjusted the idle air mixture screws with zero success i still get the popping out the exhaust no matter what i do with the idle air mixture screws.
I can set the idle air mixture screws to read the highest vaccum reading from my vaccum gauge and that dont work i can richen them up and that dont work nothing works with the idlke air mixture screws
I know that i am not in the transistion spot of the carb my idle is turned down pretty far and with all the extra timing is idle at about 800rpm.
My question is what can i do to solve this? obviously the engine wnats more fuel at an idle wich i can not give it with this edelbrock because there is limited adjustability on these edelbrock carbs, So is my last option limited to turning the vaccum advance canister down a little bit at a time untill i dont hear the popping at an idle? I called don at fbo systems and told him i was thinking about running my vaccum advance off of ported vaccum and he about tore me a new ***** hole when i mentioned that and he insisted that it must be ran off of manifold vaccum. His solution was for me to buy a 500 dollar quickfuel carburetor with a 4 corner idle and adjustable idle air bleedrs, while that does sound appealing i dont have that kind of money right now for a carburetor.
So its looking to me like i can ether turn down my initial timing, wich would require me to lengthen the mechanical advance so that i coul;d maintain my total of 32 degrees, or i can turn down the vaccum advance so that it does not add as much advance at an idle while connected to manifold vaccum. What do you guys think? please help me with this i am beyond frustrated with this. The engine is running amazingly good pulls super hard and is very responsive the only issue i am having is this popping out the exhaust crap while its at an idle and thats the only problem i am having, other then that its running the best i have ever had it running.
