Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - need help in getn to a 6k shift point drag race for blower car
  #24 (permalink)
Old 12-17-2012, 12:29 PM
painted jester's Avatar
painted jester painted jester is offline
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
I posted this on the wrong thread the other day LOL It was meant for this thread (better late then never)!! LOL
Here it isPositive-displacement or "Roots-type" superchargers tend to produce massive power at low rpm and taper off higher in the rpm range; from Idle to about 5500 Rpm on a low boost engine which is usually on the street or a weekend warrior!
You converter and cam don't come in till late and are wasting all your torque your putting out at your lower RPMs with a roots supercharger. Right off idle an engine with a Roots supercharger will typically have nearly full boost and massive power. This power increase will be fairly constant throughout the RPM range. Till it reaches an rpm point that the supercharger begins to lose efficiency!
Turbos are the other way around! low boost at idle and as rpm comes up boost increases to high rpm so you need high stall speeds and cam's that come in late!
Sorry its late LOL Jester
