Need help with Heater Hoses on A/C Unit - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-16-2008, 07:27 PM
I have an Vintage Air A/C-Heater Unit that I am trying to hook up. I want to hook up the heater hoses to the unit under my dash. My question is this--does it matter how the heater hoses get connected to the two connections on the A/C/Heater unit? I have two connections on the unit where the heater hose slips over each one--obviously one is the inlet and the second is the return line---but I don't know if it matters where you connect the inlet or the return to the two lines. Any help would be appreciated.
George
Old 02-16-2008, 08:35 PM
powerrodsmike's Avatar
Wiki Edits: 161
If your unit has an upper and lower connection. the hot water from the motor (manifold connection.) goes in the upper.
Vintage air has a place to download instructions for your particular unit.
The hose routing is included in those instructions.
http://www.vintageair.com/downloads.asp
Later, mikey
BE different....ACT normal.
Old 02-16-2008, 08:45 PM
1930u's Avatar
Last journal entry: 1930u Its just been sitting
George
Take a look at the hose arrangement on another vehicle. I think the larger 3/4" hose is the suction or return to the water pump. The 5/8" smaller line is the pressure hose leaving the pump and supplies coolant to the core. I think this is right. If you use the small hose on the suction side of the pump it might cavitate or not pump efficently.
Old 02-17-2008, 04:23 PM
Heater hose routing on A/C Heater Unit
Thanks Mikey and 1930---the download from Vintage Air was a big help. I knew I could count on you.
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
A/C & heater lines Bart General Rodding Tech 1 11-13-2006 09:00 PM
A/C Unit ?? small compact units?? BadA$$37 General Rodding Tech 2 09-16-2006 09:21 AM
Want to delete A/C but keep heater gms4233 General Rodding Tech 2 08-13-2004 08:22 PM
