Need Help On Hopping Up A 86 305 - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-07-2009, 05:38 AM
Whats the 1st mod I should put on my 86 305 engine to make the biggest gains? Not really lookin to go to a bigger engine tryin to keep the original but just gotta make more power...
Old 12-07-2009, 05:52 AM
70455's Avatar
Headers, and change gears in the rearend.
Old 12-07-2009, 06:14 AM
Thanks
I was considering going with Hooker Headers but what kind of gearing should I look at?
Old 12-07-2009, 06:55 AM
bondo's Avatar
Ayuh,... That'll depend on what you're startin' with...
Old 12-07-2009, 07:06 AM
70455's Avatar
The Grand Prix has pretty high gears. Something around 3.23 or 3.42 would be good.
Old 12-07-2009, 07:52 AM
Good deal! I appreciate it. Im wanting to push around the 300-400HP range. Im looking into heads,Intake,and a Carb.
Old 12-07-2009, 09:18 AM
I received a response about some 86/305 heads. IF your cast.# is 4416 or 4440 they have the good 58cc chambers and decent runners. Just have 1.94/1.50 valves put in them and do some bowl work and "clean-up" porting. Cam change...headers....intake and carb and you should be on your way to much bigger HP.
6sally6
Old 12-07-2009, 10:49 AM
70455's Avatar
If you want 400hp you would be better off building a 350 making it a stoker.
Old 12-07-2009, 12:28 PM
my87Z's Avatar
Veteran/Firefighter-Paramedic
kinda X2, you dont need a stroker to make 400hp out of a 350, that's easy, but that's alos another topic
if you find a decent set of 416 heads to as mentioned before, put a mild cam it maybe around a 208-212 duration @ .050 a better intake and carb, headers and better exhaust, with this you should have to much problem makeing maybe about 300hp and likely close to 350tq
Old 12-07-2009, 12:47 PM
bigboytoyracing34's Avatar
never too fast
go with 3.29 for a grand prix
Old 12-07-2009, 08:51 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
You'll spend a lot more money getting a 305 to 400 hp than you would if you bought a 350 and built it... even factoring in the purchase price of the 350 if you're careful. And you'll have gobs more torque and streetability... but its your car so do whatever makes you happy. That's the most important part.
But keep in mind, you're starting with an engine that makes 150 hp. You're hoping to almost triple its output. Prepare to spend several thousand getting there, especially considering you'll need to spin it to 6000+ rpm to get it. High RPMs aren't cheap. Or, spend $1100 on a reman 350 vortec, use a 224/234 cam, and make 400 hp before 5700 rpms.
Old 12-08-2009, 12:27 PM
70455's Avatar
You wouldn't have to build a stoker, but it's cool to have one. I built a 305 one time built it to around 300 hp never was happy with it. Later same car built 350 around 350 hp it cost less money and ran a lot better and it was in a 81 Grand Prix with 3.73 gears, but that was back in the when gas one dollar gallon. So low gears where cool back than 3.23 with a mild 350 would be the way to go.
Main thing is good flowing heads, higher compression pistons, good cam, headers, good intake and carb. Right gears in the rear end.
Old 12-09-2009, 04:24 PM
I had a 305 from a 86 camaro, took it .040 over with new kb 10.1 pistons, summit racing .465/488 lift cam, torker II intake with holly 650DP carb, heads got new springs and 1.6 rocker arms (stock is 1.5) which made a .496/520 lift cam, hooker headers full tube 1 5/8... 3k stall converter, th350 tranny, and installed it all in a 91 s10 with a 7.5 10 bolt, 4.11 gear stock rear end, ran a 10.35 @ 134 mph, and could have gone faster but got kicked out for no roll cage in the truck! It had a lot more power over my ford 351c, mild build motor
Old 12-09-2009, 05:27 PM
ericnova72's Avatar
More for Less Racer
I call BS here, calculater says you would need 545 hp to move a 2900 lb vehicle to those times. There is no way a naturally aspirated 305 makes that kind of power without a power adder, especially with that parts list- Hydro cam, Torker II .
Let me guess, Genie in a Bottle(NOS), right?? Go blow your smoke at someone else.
Old 12-09-2009, 05:48 PM
You can think what you want, I KNOW my times. Truck weights 2050 lbs with driver, No NOS, 22" wide slicks, the 4.11 gear help out a lot too! Dyno put me at 437hp and 478 torque....
If you don't have anything nice to say....DON'T say anything at all!!!!
Connector ident?? 86, GM 305 monte carlo bubbahotep Electrical 4 11-02-2008 08:22 PM
are these stock in a 86 irockz 305 86irocz Engine 12 07-14-2007 10:53 AM
86 silverado 305 CraptasticLucky Hotrodding Basics 11 06-15-2004 11:39 PM
305 in 86 elky walkingwolfmike Engine 2 04-20-2003 10:54 PM
86 - 305 what cam? Iroc'o Engine 2 10-09-2002 06:43 PM
