need help on how to rebuild a 4l60e on a camaro - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-04-2009, 11:11 PM
hi i have a 4l60e that i want to try to rebuild but i cant find any sites on how to do this can any one help me thanks
Old 06-05-2009, 06:31 AM
Crosley's Avatar
Wiki Edits: 1659
There are books and videos to purchase that help a DIY to replace parts in the trans.
Old 06-05-2009, 08:18 AM
4l60e
is there any sites you know of and do you know how to rebuild this 4l60e
Old 06-06-2009, 11:39 AM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
I do not know of any site that would be comprehensive enough to take a novice through a 4L60-E step by step.
ATSG books are very concise. Haynes books are ok too. It's ok to read books.
Old 06-06-2009, 02:15 PM
Crosley's Avatar
Wiki Edits: 1659
Buy a book or find competent help on the 4L60e trans... many areas of the valve body need addressed/ checked during a rebuild besides replacing parts the DIY will do.
I build transmittins for a living... about 200 of the 4L60 trans a year among the other stuff.
Old 06-06-2009, 05:04 PM
4l60e
ok thank you this will be my first time doing some thing like it is there any tricks you can tell me about
Old 06-07-2009, 12:05 AM
C-10's Avatar
Revolution Calling
Tricks...hmm. Those really have to be learned by the individual. My tricks may not work for you and vice versa.
A few:
Take detailed quality digital photos for reference. Note any and all witness marks on hard parts, especially pump vanes. Reinstall hairpins that secure solenoids from the bottom up when the VB is disassembled. Never wipe parts off with 'rags'. Clean and forced air dry only.
Tools, books and specialty tools lessen the need for 'tricks'
ATSG has an update handbook for 4L60E and 4L65E. Might consider this one as well as a basic teardown & reassembly book.
Intelligence is a good trick too.
Old 06-07-2009, 08:05 AM
4l60e
ok that is helpful thank so now i have some what an idea now. but i came across another problem my car pushes 500hp and the rebuild i was getting turned out to be a stock one what should i do when i am making that much hp
Old 06-08-2009, 07:58 AM
SSedan64's Avatar
http://www.technicalvideos.com/video...smission.phtml
http://www.makcotransmissionparts.com/4L60E-4L65E.html
http://www.makcotransmissionparts.co...5Emanuals.html
Carb rebuild - won't start now. Please help? joe99 Engine 6 11-30-2011 03:04 PM
1990 camaro tranmission rebuild or replace?? hondaca Transmission - Rearend 2 08-14-2008 05:55 PM
350 Engine rebuild CamMan Engine 35 06-01-2006 02:32 PM
69 Camaro front suspension rebuild 69Z Suspension - Brakes - Steering 9 10-22-2003 08:38 AM
94 Camaro lt1 Vs. 95 Camaro lt1 NEEDHELP Engine 3 11-05-2002 11:45 AM
