the wires for the pcm side of the fast wiring harness are:
1. the two main PCM connections
2. brake switch
3. check engine light
4. 4k pulse for electronic speedometer
5. tachometer
6. ALDL
7. Throttle Actuator Control Module 2 (TAC-2)
8. Battery
9. To ignition switch hot with key in on and start positions
10. fuel pump relay
serial number for the harness is 1554. (idk if that helps..)
Im not using the FAST pcm. im going to be using the stock PCM that came from the 2001 camaro the motor came out of. I dont think i am going to connect the evap system stuff at all. (i live in texas) lol
If i bought an all digital guage cluster (from dakota digital) would all the necissary wires be able to connect to the guages or do i need to look for a specific kind of guages for my wires? just dont want to spend $800 and it not even work.
