Need help I.D.> B/W T-10> GM - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-16-2011, 06:15 PM
55project's Avatar
I'm looking to pick up a nice 4 speed for my new project and came across a T-10- or ST-10, not sure which due to the tail shaft?
The case # is> 13-04-065-903
and has F P C 4 under that,
looks like date code is 1978 or 1979
The tail is hard to make out 13-04-066-908 ( or 903) ?
The input shaft is a Fine spline with NO rings
And the tail shaft is a 350 Yoke, ( not a 400 yoke)?
I'm usually prettygood with finding the info i need on these 4 speeds, but this on has me stumped. The only T-10 i know of with a fine front and a 350 tail is an 1982 Camaro box, but the shifter is in the right side of the tail, this is correct on the left.
ANY help would be great, and give me an idea what i should offer this guy if the guts are good.
Also if you know what the first gear is suppose to be that would help.
Thanks
Old 06-16-2011, 10:50 PM
Could be this:
http://www.chevelles.com/forums/showthread.php?t=69730
Here`s some more info:
Transmission Information.
Old 06-17-2011, 02:04 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Thanks
W/o the partial VIN, it might be an '82 F-body Pontiac w/3,42 low, alum. case, 350 output.
The partial VIN is usually stamped on the passenger-side boss.
Example: 1BN100005 = Chevy, 1981, Norwood, 5th vehicle
What is the date code? It's stamped on the driver side of the case. The next to the last number is the last digit of the year.
Example: WB2472 = Warner Gear, B =February, 24, 1977, 2nd shift.
Old 06-17-2011, 04:37 PM
55project's Avatar
I'll contact the seller and get back asap.
Thanks
Old 06-19-2011, 04:16 PM
55project's Avatar
OK,, i hope your still here..
The seller is MIA, but my daughter just told me that we still have her old
S-T-10 in the shed , I would really like to know the first gear and any other info, here is everything on the pass side>>
Upper box> 27N191014
date says> 8-7-77
13-04-065-903
W.G. Div.
F C2
P
And it has 2 rings on the input shaft
Old 06-19-2011, 04:50 PM
55project's Avatar
I just went back out and found this on the shifter, (d/s) >> WC3072
Old 06-19-2011, 05:04 PM
55project's Avatar
OK, Let me know if i got this right, I found a site with some info>
It's a 1977 Pontiac S-T-10
Plant> Norwood, Ohio
and has a 2:43 first gear
I got more info, but this covered what i need. My main thing is the first gear info i found correct?
Thanks,
