need help, I want to put a 95 LT1 in a Jeep - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2003, 10:51 PM
Ok, I got a 305 4 bbl in it now, I want to put a LT1 from a 95 camaro, I've got a line on the motor but, will my headers work and will my TH350 work with it, I need most sensors and wiring harness and computer and will my power steering and alternator mount and brackets bolt up, will my starter work to, any help will be good, I know I got a to put a electric fuel pump in, I'm more worried about everything bolting in place, headers, motor mounts, power steering bracket and alternator,
Thanks Rob
ostman1234@hotmail.com
Old 06-18-2003, 09:07 AM
superrodder's Avatar
Thumbs up
Go for it the engines should use the same acesseries,except for the front drive pulley pieces.starter flywheel is also different.
lots of work and you'll need a custom chip burned for the computer to get it to run correctly,but it should run great once it's tuned.
Good luck
Old 06-18-2003, 09:39 AM
bad429's Avatar
Check back issues of offroad or 4wheeler magazine they did a project jeep not long ago. It was a tj. Ill check my mags see if i can find the one. MITCH
