On the straight 6 engines casting #, it is on the back on the passenger side of the block, hidden or almost hidden by the starter, or along the middle bottom of the block, possibly hidden by an motor mount.
The casting# should be 6 to 9 digits long. Cole Last edited by eloc431962; 08-27-2011 at 06:43 PM. |
Hmmm, I was told that it was to the left of the dizzy where I found that one in the first pic. Don't know if my old body can get the digital to take pics in those locations you mentioned or not but I'll see what I can do. I may end up with the trial and error method on the valve cover gasket but I probably need more accurate info if I stick an electronic ignition in it, huh? The plug wires are horrible and need changing so I probably need to come up with a plan. I"ve never had any experience with an electronic ignition so I'll need to find some tutorials and get familiar with them.
Cole
OK, I have done my homework and here's what I've got. Thank God for the Digital Camera
The Engine Serial # which I originally posted here F309A Now I have the Head Code on manifold side 3836848 GM12 Block Casting Code below the dizzy hole to the right 3764478 This was on the side of the head between 2&3 B23 848 850 The Block Date Casting Code was hard to get but here's what it appears to be: CON 4 ?088 I may have to remove the solenoid to get that last number if it becomes necessary to be able to identify. |
I think it's a #6 rather a #8 in the casting.
could the # be 376447(6) instead of 376447(8)
if so you have a 235 from the year 56-62 235 engine casting # 3764476 . http://www.inliners.org/becks/BCN2.html ColeI |
Look like it's a 235 to me Em.
here's what the head # came back as Em, 1956 3836848 235 engine.
Cole |
F = Flint
3= March 09 =9th day of the month A =235 Standard engine Cole
'56 gmc
Hey Man, I'm glad you got your truck safe and sound. Seems to me you've go a Chevy engine in your GMC. While I'm not sure about, I believe the GMC small truck six was a 270. Appears you've got a Chevy 235 3764478(6). Here's a link to a service manual;
http://chevy.oldcarmanualproject.com...5559mm000.html Nolan |
It might be a Canadian built GMC....They had Chevy engines in them....If it is, it might say "Made in Canada" on the firewall tag
Ontario Rodders |
| help identifying engine | cokeman277296 | Engine | 2 | 09-28-2007 06:23 PM |
| Identifying my engine | MrPhotographer06 | Engine | 2 | 06-22-2007 05:42 AM |
| Please help - Identifying my engine | Trans Am Tony | Engine | 6 | 04-26-2007 07:18 PM |
| Help Identifying an Engine | baddalaskan | Engine | 12 | 04-09-2007 02:16 PM |
| Need Help Identifying Engine | Kiknazz101 | Engine | 6 | 04-01-2002 02:51 PM |
