Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - need help identifying pistons
Old 12-05-2012, 04:21 AM
BOBCRMAN@aol.com's Avatar
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
Originally Posted by cdminter59 View Post
Is the oil pan still off or have you installed the engine already? The only way to find out is look at the underside of the piston for a part number . Maybe a Ford guy can recognize them.
Doubt if Ford guy can tell. It's a small block chevy. Pistons look like cast replacement from here. As mentioned, check for brand/no. on inside of skirt.
