need help identifying pistons - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-04-2012, 09:01 PM
http://i173.photobucket.com/albums/w...117/IMG003.jpg
these are stamped .60 over
anyone know what brand they might be or if they're cast or Hypereutectic
Old 12-04-2012, 09:37 PM
pistons
are there any markings on underside of piston?
Old 12-04-2012, 09:40 PM
I didn't really check for any before I put the engine together
Old 12-05-2012, 02:06 AM
Is the oil pan still off or have you installed the engine already? The only way to find out is look at the underside of the piston for a part number . Maybe a Ford guy can recognize them.
Old 12-05-2012, 04:21 AM
BOBCRMAN@aol.com's Avatar
Doubt if Ford guy can tell. It's a small block chevy. Pistons look like cast replacement from here. As mentioned, check for brand/no. on inside of skirt.
Old 12-05-2012, 05:15 AM
hcompton's Avatar
Old & Furious
They dont look like cast rebuilder pistons to me. They have a knotch on the one side and the ring looking thing in the middle. Is this an old build they look like old style after market pistons.
With the marks and the thing in the center of the piston. I would not run them unless they were my last choice. They look like they will cause hot spots and preignition. Are they drilled for expansion. Might be for extreame heat.
But without the exact part number there is no way to tell if they are good or bad. So anything answer will be a WAG on my part.
Old 12-05-2012, 02:06 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Pistons w/the machine tooling locating divot like that aren't seem much any more, but they used to be common. Mainly on pistons like Badger and Silvolite. Good chance they're cast non hypereutectic.
Need some help identifying pistons sherman8r Engine 9 01-22-2010 08:59 PM
identifying pistons?? 2wld4u Engine 12 01-15-2009 10:29 AM
Need help identifying my 400 chevy pistons. 71Nova400 Engine 1 08-25-2007 12:14 PM
Help with identifying a T-5 sleepr Transmission - Rearend 2 11-20-2005 08:47 PM
