Need help identifying Quadrajet - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-03-2012, 05:31 PM
Supporter of the 4.3 liter V6
I have a quadrajet carb off my 86 4.3liter truck that i took off years ago for an Edelbrock 600, but gas is too expensive to justify that size carb these days. I need help identifying my qjet so i can get rebuild kits and throttle shaft bushings. The first number is 17086046, and following numbers are 2265 jpj. Mine has dual capacity pump but not computer controlled. Could someone please help me out
Old 04-03-2012, 07:02 PM
LATECH's Avatar
170 is the prefix, it started in 1976, not sure about the meaning of it
86 is for 1986
0 is the emission code
4 is the GM division of buick
6 is for the trans type. Even numbers are usually for automatic odds for standards
Old 04-03-2012, 07:10 PM
Take the 17086046 number to NAPA and let them look you up a kit.
Old 04-03-2012, 07:31 PM
The Buick part threw me a loop because the carb came stock on the truck, a Chevy? Some sites say Rochester doesn't always follow those labeling guidelines? Thanks for the suggestion about Napa, i'll be showing my face in there pretty soon. If anyone can tell me if its M4M or E4M or one of those i would appreciate it. Thanks!
Old 04-03-2012, 08:27 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
After about '80 the numbers got pretty skewed. Your carb is original to that engine.
I have a similar carb, 17086047 from a 1986 4.3L V6 Sierra w/MT, 800 CFM. Date code: 0226, and “JPK” build code. Came w/74 jets x 55A primary rods; EH secondary metering rods on a “J” hangar.
Just use the carb number (17086046) you posted to get a kit (the other codes aren't needed to order a kit). The carb kit for it if using a Walker kit (sold at O'Reilly, etc.) is 151097.
Short wiki page on on the dual capacity accelerator pump Q-jet is HERE, other Q-jet carb info HERE.
Old 04-05-2012, 07:01 AM
Thanks I really appreciate it! 2 years ago, the Edelbrock was the best decision i made, i loved the power but now that fuel has reached 4 dollars in Florida, im going to love those tiny primaries alot more on my Qjet
Old 05-18-2012, 01:38 PM
ronbuhg's Avatar
E4M is for electric choke and M4M is for manual choke ,i believe thats correct.good luck & happy cruisin !!
Old 05-18-2012, 02:23 PM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
I have purchased 2 QJet rebuild kits. Each from a different company. Both kits will rebuild all versions of the carbs (you just end up with a few parts left over and gaskets that don't work on yours). In fact I bought one today from O'Reilly's for $18. Have fun!
Converting from external choke quadrajet to electrical choke quadrajet silentpoet Hotrodding Basics 4 10-03-2011 02:38 PM
Need help in identifying BlackScorpion Engine 27 07-28-2008 04:59 PM
Help with identifying a T-5 sleepr Transmission - Rearend 2 11-20-2005 09:47 PM
Identifying Quadrajet Ports on throttle body... flipp121 Engine 11 05-19-2005 10:27 PM
