Need Help IDing Muncie - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-08-2005, 06:08 PM
Barz51's Avatar
a.k.a. Rusty Shackelford
Last journal entry: Another one
I picked up a manual tranny yesterday and was trying to ID it. I pulled all the number I could read. Thanks for your help.
The side cover reads:
X
GM8 3858982
B 77 (B maybe an 8)
The case reads:
GM 7
3858988
K 28
The tail shaft reads:
3860042 GM
There are 10 splines on the input shaft and 27 on the output shaft.
The side cover looks exactly like the Muncie example in this pic.
Thanks again for your help.
Old 05-08-2005, 08:29 PM
302 Z28's Avatar
Tons of Muncie identification information at www.5speeds.com.
Vince
How many horses can u run with a muncie 4-speed(stock) neil madsen Transmission - Rearend 7 02-07-2006 12:10 PM
Muncie shifter adjustments needed? Jims64 Transmission - Rearend 2 12-21-2004 11:01 PM
Swapping a Muncie SM465 to a TH-350 on a FS Chevy Truck TL-Iguana Transmission - Rearend 1 08-22-2004 05:54 AM
muncie 4 speed ID friend Introduce Yourself 2 08-21-2004 05:56 PM
Speedo gear tooth count on a Muncie? zachscc Transmission - Rearend 3 01-23-2003 06:10 PM
