need help on installing door glass/1946 ford - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-28-2013, 06:46 PM
I carefully packed, sorted and numbered all my pieces when removing all the parts on my 1946 Ford. After 10 years of welding, replacing parts, blasting, painting, etc. I have lost my directions on how I removed the door window glass. Forget memory, sometimes I forget what I had for breakfast let alone 10 years ago. I have replaced the front and rear felt channels and the split felt trim holding the glass. Purchased the glass install kit from Early Ford. I forget the order to install the glass. Could anyone out there give me some help on what item goes in first, second, etc. The hand crank assembly, vent wing channel, glass, there also is a window channel at the bottom of the window, does the pointed end of that channel go toward the rear or the front of the car. Help would much be appreciated. Thanks again Joe
Old 01-28-2013, 07:56 PM
Wiki Edits: 27
ford V8 club
Try the Early Ford V-8 Club Forums, 32 to 48 cars and trucks, ford experts hang out there. Some of the guys get pushed out of shape if you mention installing anything other than vintage speed parts and accessories.
1946 Ford 2 door scheetz_21 Hotrodding Basics 0 12-04-2012 02:15 PM
Installing door glass 39chevy Body - Exterior 0 04-19-2009 06:41 PM
30U Installing the door glass???? 1930u Body - Exterior 2 01-02-2009 11:58 PM
Installing glass in 51 ford pickup chopped top northportman Body - Exterior 2 08-31-2007 06:59 PM
1946 ford 4 door whats it worth? mikeweyman Engine 3 04-06-2003 06:48 PM
