Need help on installing a modern roller cam in an older big block chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2011, 02:35 PM
I was looking around and I found a place that sells Generation 5/6 big block Chevy roller cams. They are new takeouts from 454/502 engines. They say you can use retro style roller lifters and a Gen 5/6 timing chain setup. The cam has no lobe for a fuel pump so an electric fuel pump would be required.
This is a very mild roller cam and I think it would be perfect in my stock 402 big block.
Has anyone done this? Are there any other items or issues I would run across?
Thanks for your time,
Old 11-27-2011, 06:01 PM
BOBCRMAN@aol.com's Avatar
I have done several.. You can use the complete later model stock single roller drive with t-plate or go for an aftermkt true roller. Only a couple of companies offer these..
The expensive part is the "retro" hyd roller lifters with tie bar.. DO NOT buy the cheaper ones mkted on the net. Ebay etc. Chineese junk.. Full of machine crap or the tie bars break.. Have seen several failures..
Old 11-27-2011, 06:40 PM
Thanks Bob for your help.
It's too bad the retro roller lifters are expensive. You can find the newer roller lifters on Ebay for good prices.
Older Chevy Block, Newer Fuel Infection texascaraudioman Engine 1 10-05-2008 11:51 AM
Installing Roller Camshaft in Mark IV Big Block - What Mods are Required? leejoy Engine 23 12-18-2007 03:51 PM
installing a big block in 55 chevy beetle9 Engine 6 09-07-2004 01:01 PM
older block to newer roller eight90 Engine 5 10-01-2003 11:35 PM
Installing Turbo 350 onto Chevy small block Help ecarpener21 Transmission - Rearend 9 05-13-2003 10:17 PM
