Need help lowering 78 Mark V - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-23-2003, 05:19 PM
Exclamation Need help lowering 78 Mark V
I have a 78 Lincoln Mark V that I want to lower. I've searched for dropped spindles with no luck, so I'm thinking about cutting the coils, how much can I cut from the front coils without having a problem? The rears shouldn't be to much of a problem.
Look forward to hearing some opinions.
Thanks
Robert
Old 06-24-2003, 05:40 AM
aka Duke of URL
I would try and find lowering springs to retain some ride integrity. Usually cutting coils will make the remaining spring much stiffer.
But if this is the way you want to go, remove (cut off tool) one quarter of a coil at a time until you get the desired trim height. It's not going to cost you anything, other than time to try it first.
