Need help making my 4L80e shift - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2010, 08:33 AM
I'm taking a 454 & 4L80e out of a 91 chevy suburban & putting it in my 85 chevy dually. I'm switching it from throttle body to carburetor so I can't use the sensors. I need help figuring out how to make the tranny work w/ the new set up. The 4L80e has wires that connect to it on the side....I've heard that I can connect 1 of the wires to the battery & the other to a TAC & it would shift properly.....not sure.....somebody PLEASE HELP!!!!!
Old 08-24-2010, 11:31 AM
The only way this transmission shifts is through the use of solenoid valves that control fluid flow inside the transmission. You CANNOT simply connect one or two wires and have it shift. The only ways to get it to work properly are to 1) buy an aftermarket trans controller for about $1000 or so, 2) find a standalone trans computer from a 91-93 diesel truck with a 4L80E, or 3) hardwire the solenoids to a set of switches on the dash and manually shift using the buttons.
Old 08-24-2010, 05:42 PM
Joe....thanks for the reply.....I actually have the vehicle (91 suburban 2500) that the motor & tranny came out of w/ all of the wiring & modules.....just don't know what to take off....can you tell me which modules need to come off & where they're located??? Again thanks for the knowledge bro
700r4 shift / tv question mican99 Transmission - Rearend 3 05-04-2009 09:08 PM
C4 no shift 1953 Homer Transmission - Rearend 1 10-15-2008 02:35 PM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 12:48 PM
700r4 won't shift at WOT Alex99 Transmission - Rearend 39 02-15-2005 09:08 PM
TH400 rebuilt delayed shift into "d" oklowride Transmission - Rearend 7 12-14-2004 09:39 PM
