need help with manual trans ID
I pulled the driveshaft off today and redid the u-joints & rear trans seal on my '72 camino today and while I was under there I pulled some numbers off the trans (two birds one stone :D)
it's a manual 4 speed it says GM 3925658 then it has an NF but the F is attached to the right leg of the N that is followed by a small o and a larger 2 ---All this is on the passenger side sorry if thats a little confusing just trying to describe it as accurately as possible :) thanks in advance |
Is it a cast iron case....aluminum case....????
http://hotrodders.com/showthread.php?s=&threadid=23626 |
Iron case, I'm pretty sure its a muncie as the first 5 numbers match what's on an m-20/m-21 (39256) its just the last two (58) that have me perplexed
Muncie uses an aluminum case. Saginaw has an iron case with all three shift levers in the side cover. ID info for various ratios can be found at www.dandltransmission.com
| All times are GMT -6. The time now is 12:44 PM. |
