need help with manual trans ID - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-30-2003, 12:09 AM
Scuzzy's Avatar
Certified Cruck Lover
I pulled the driveshaft off today and redid the u-joints & rear trans seal on my '72 camino today and while I was under there I pulled some numbers off the trans (two birds one stone )
it's a manual 4 speed
it says GM 3925658
then it has an NF but the F is attached to the right leg of the N
that is followed by a small o and a larger 2 ---All this is on the passenger side
sorry if thats a little confusing just trying to describe it as accurately as possible thanks in advance
Old 09-30-2003, 01:23 AM
Sandflea427SS's Avatar
Anything with a throttle
Is it a cast iron case....aluminum case....????
http://hotrodders.com/showthread.php?s=&threadid=23626
Old 09-30-2003, 11:46 AM
Scuzzy's Avatar
Iron case, I'm pretty sure its a muncie as the first 5 numbers match what's on an m-20/m-21 (39256) its just the last two (58) that have me perplexed
Old 10-02-2003, 12:27 AM
Muncie uses an aluminum case. Saginaw has an iron case with all three shift levers in the side cover. ID info for various ratios can be found at www.dandltransmission.com
