Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - need help on master cylinder
Old 06-22-2006, 03:29 PM
xntrik's Avatar
xntrik xntrik is offline
Save a horse, Ride a Cowboy.
Originally Posted by gun70runner
Im building a 66 mustang.. need info for master cylinder and break assembly..
I have 75 granada front spindles and hardware.. need help figuring out what master cylinder to use and brake pedal assembly. The granada was disc manual.. and if there was anything else im forgetting ..Thanks for any help
Granada MC (1") and combination valve is a direct bolt in.
If you want a lighter pedal pressure use the '79 Mustang (7/8") manual cylinder. It is the only Fox MC with inches sized fittings.
