need help on master cylinder
Im building a 66 mustang.. need info for master cylinder and break assembly..
I have 75 granada front spindles and hardware.. need help figuring out what master cylinder to use and brake pedal assembly. The granada was disc manual.. and if there was anything else im forgetting ..Thanks for any help 'wayne |
most people use the '67 Mustang frt disc master.
Granada MC (1") and combination valve is a direct bolt in. If you want a lighter pedal pressure use the '79 Mustang (7/8") manual cylinder. It is the only Fox MC with inches sized fittings. |
| All times are GMT -6. The time now is 07:40 PM. |
