need help on master cylinder - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2006, 06:43 PM
Im building a 66 mustang.. need info for master cylinder and break assembly..
I have 75 granada front spindles and hardware.. need help figuring out what master cylinder to use and brake pedal assembly. The granada was disc manual.. and if there was anything else im forgetting ..Thanks for any help
'wayne
Old 06-19-2006, 07:27 PM
Wiki Edits: 31
most people use the '67 Mustang frt disc master.
Old 06-22-2006, 03:29 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
'wayne
Granada MC (1") and combination valve is a direct bolt in.
If you want a lighter pedal pressure use the '79 Mustang (7/8") manual cylinder. It is the only Fox MC with inches sized fittings.
Dual Master Cylinder Brake Pedal with Balance Bar iceman36 Suspension - Brakes - Steering 6 02-24-2006 12:55 PM
39 Deluxe master cylinder adapter? MM in NM Suspension - Brakes - Steering 4 09-30-2005 03:42 PM
Confusing master cylinder ports... Externet Suspension - Brakes - Steering 2 12-08-2003 08:18 PM
Help with continuing master cylinder problem chris57 Suspension - Brakes - Steering 3 09-30-2003 02:35 PM
Help! Going Nuts! Mysterious Master Cylinder delstretcho Suspension - Brakes - Steering 6 03-11-2003 05:54 AM
