Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need Help on my 1978 Camaro, Intake/Carb
Old 11-27-2010, 07:07 AM
Greg T's Avatar
Greg T Greg T is offline
www.krusinklassics.net
Run the hot wire to a switched HOT on the fuse panel. Be sure it's hot only in the ON position and not the aux position on the key. If there is a ground wire you may use one of the carb's mounting bolts.
