need help with my 305 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-04-2010, 02:14 PM
i took off the tbi and put a carb on it that turned out to be junk its an old holley carb i found on craigs list gonna just buy a brand new one.(i didnt want the computer any more)i need help rewireing the fuel pump wires i cut off all the wires from the harness i didnt need and cut the fuel one by mistake whats an easy way to rewire it i cut them to close to solder them back on
Old 08-04-2010, 07:50 PM
might get more help if you say what your vehicle is
Old 08-05-2010, 07:43 AM
1992 chevrolet caprice classic
Old 08-05-2010, 01:53 PM
Mopar or no car.
92's probably too new of a car to dump the computer. everything on that car is going to be controlled by the computer.
Old 08-05-2010, 05:40 PM
on a 92 the only thing controlled by the computer should be the engine and torque converter lockup
Old 08-07-2010, 07:02 PM
bigdog7373's Avatar
Of course it's fast
It sounds like you're using the tbi fuel pump with the carb. That pump will supply way too much fuel pressure to the carb and will cause it to suck. You need to get a pressure regulator or a different fuel pump to make it work. After doing this, if the carb still isn't performing to its full potential i would suggest taking it apart and cleaning it up and rebuilding it if necessary, it will be much less expensive than buying a new one.
stroked 305 85CHEVY Engine 50 07-24-2010 01:38 PM
305cid/372hp who said it couldnt be done King Kong Engine 41 11-11-2008 04:41 PM
dirt track 305 groomer Engine 12 04-20-2008 03:46 AM
mild performance out of a 305 77formula Engine 4 10-23-2006 09:57 AM
305 head on 350 savman1 Engine 4 10-15-2006 10:18 PM
