need help with my 454 build
hey guys, new here and figured you guys might be able to help me out, might as well start off with my project, i have a 81 chevy pickup that i want to put some horsepower in, its just a 2 wheel drive short box, problem is i can't make up my mind in which direction to go, right now i have a supercharged 454 with a b&m 174 blower on propane, it works well but i want to put that motor back in my 4x4, so modifying that is out of the question lol.
i currently have a brand new weiand 144 series and i have a 400 sb sitting in my shop but i dont think that will make enough horse to make me happy, what i want is nice daily driver that makes around 600 to 700 horse and runs smooth... so i came across a couple of new garrett turbos from a friend that i can get for $1500 for the pair and run for $1200 a piece. my friend with the turbos has been racing for a long time and said they will spool up around 2200 rpm on a 454, and he said if i want to make power i should ditch the propane which i dont have a problem with, i have an extra 454 kicking around and i can easily find a set of large oval port heads so this is one option. i was also thinking about buying a 671 blower for the 454 but then again i'm not sure what i could get for horsepower out of it and i don't want a really loud whine sound from the blower, i haven't heard a 671 in person before so i don't no exactly how loud they are. and i will take my truck when its done to the dyno in town to see exactly what the numbers are and well last of all i was thinking about running an all engine 454 which i have a steel crank for to start, but then again i dont want nothing all cam'ed up that doesn't idle and i want it to make power right now. and of course its about making horewpower for the right price, decent fuel mileage would be nice but you can't have everything... so basically have to make up my mind so i can start building, so what do you think is the right combination... thanks for the help |
i was just thinking that the twin turbos would run kinda nice on the street and you dont see a twin turboed big block in a truck up where i live. and i want to be my daily driver so it would see some cold weather too so i thought the turbos might be better
and for the price of buying a 671 blower; i'm sure the cost would be around the same overall to set up the turbos
Turbo's
would be easy and idle smooth and give you the HP you want. You can blow through the propane mixers (using Impco?) and you can get Mixer hats to easily hook the pipes up to. You would need 2 mixers for the hp you want but they make a Y adapter to mount 2 on a standard 4 bbl intake. Intercooled? just use the best exhaust valves you can get and watch your exhaust temps!
thanks for the advice, i would really like to do twin turbos with propane, i do have 3 mixers i think, 1 ohg and 2 impcos, however i heard ohgs are better for turbocharging but some people might argue that, and i'll put a air to air intercooler in aswell, i've been running propane on all my trucks for over 4 years and i never have any issues so i would like to keep running it. i want to run about 10 pounds of boost so i'll probably have to go to forged pistions and a decent set of rods, and i can get my hands on a good steel crank right now, and for a intake there is a dual carb setup one i'm looking at, and for heads just an older set of large oval ports, so i think i can piece together a pretty good motor
well i've been thinking about this build for quite sometime now and spend alot of time researching it, i just haven't played around with turbos yet, and i have to fab up some manifolds which i would just rather buy, and some guys here where i live have done propane with turbos but no one has ran two on a bbc
| 454 Build | 48bill | Engine | 7 | 04-26-2011 04:53 AM |
| 454 beater\sleeper build | smashem | Engine | 1 | 12-07-2009 09:16 AM |
| replacing a 454 with a 350...... | Treozen | Engine | 8 | 03-05-2008 01:28 PM |
| 454 BBC heads by FoMoCo?? | WakBordr7387 | Engine | 9 | 06-13-2006 10:30 PM |
| BBC 454 build ?? (long) | bobbypantera | Engine | 16 | 04-30-2005 11:04 PM |
