need help on my 53 pontiac chieftain - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-25-2007, 07:28 PM
Hi I've just bought a 53 chieftain, I'll live in Ireland where the road totally suck so I need to raise it(it was lowered)... I want to use an air kit but am I looking at mega bucks? all I want to do is raise the back end when driving and let it back down when parked... no messing at lights or anything...
I also want to add power steering... is there a kit available
And finally... I want to convert to disc brakes.. again is there a kit available...
Any help would be great
Thanks
B
Old 09-25-2007, 07:59 PM
If someone has put in a lowering block in between the spring and axle all would be required is removing it and getting the correct length u-bolts if thats the case. It depends on how it was lowered. Double check the springs if there isn't a lowering block in there.
Scarebird.com has a disc brake kit.
Not sure on the power steering, that may require quite a bit of work and fabrication.
400 sbc vs 400 pontiac Artemis Entreri Engine 52 09-08-2010 07:17 PM
53 pontiac 53chieftan Introduce Yourself 2 06-19-2007 01:42 AM
how to get my 53 pontiac to go pontiac jon General Rodding Tech 2 07-27-2006 01:24 PM
Pontiac will drop GTO this year ckucia Hotrodders' Lounge 10 02-22-2006 10:44 PM
53 pontiac build up questions. Super Chevy General Rodding Tech 4 06-25-2005 10:03 AM
