Need help with my rear end - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2006, 08:32 PM
chevy3600's Avatar
http://community.webshots.com/
My 1951 Chevy 3/4 ton is almost stripped to the frame. All that is left is the front end and rear end. As soon as that is done I will haul it (the frame and sheetmetal) to the blaster. I will be installing a IFS and 350 sb. I would like to find a 9 inch Ford rear end but may have to settle for something else.
Problem: Because they are so heavy dutyI would like to keep the rear springs. Is this the best way to go? Will I be able to use them with a different rear end?
Old 10-12-2006, 08:37 PM
poncho62's Avatar
Wiki Edits: 5
Sure............whatever rear you choose, the spring perches will probably have to be welded on anyways, so use the ones that fit those springs. I would think however, that you might want to remove a leaf or two to soften the ride a bit.
Old 10-13-2006, 11:27 PM
Rick 5150 69's Avatar
You might look here to find an alternative; Rick
http://50chevy.freeservers.com/Suspension_Widths.html
Old 05-04-2007, 06:40 PM
Depends!
It depends on whether you';re going to be making any horsepower or not. If you have a basically stock engien, use the leafs.
If you're making 350++ ponies, then set it up with a 3 link or 4 link. A 3 link (ladder bar) setup is a LOT easier to install for someone who has never played with these setups.
rear end / brakes, etc / INFO?? Pickup Guy Hotrodding Basics 7 08-02-2007 01:06 PM
Thump Thump in rear end?? HotRodMan Suspension - Brakes - Steering 7 01-24-2007 06:09 PM
1975 8.5 rear end camino_man Transmission - Rearend 6 09-18-2004 05:32 AM
Rear End Change black66 Transmission - Rearend 4 01-28-2004 09:21 AM
Important rear end mounting question 71gtx Transmission - Rearend 2 01-04-2004 06:05 PM
