Need Help With My T-400 Transbrake Installation - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-27-2008, 04:50 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
I purchased a Transbrake from Redneck Performance and need help with the installation. I know you all will say to take it to a tranny specialist but my budget won't allow that so I need to do this myself. My knowledge is very, very limited on automatic tranny's but I am willing to learn. I searched the internet for instructions and found that the Hipster brake is very similar to install but both Redneck & Hipster have vague (almost identical) instructions. I need step by step instructions and diagrams. I am putting this in a TH400. I was messing around with it some this weekend and I removed what I think is the cover for the modulator (right side rear) and there was nothing inside. This tranny had been built for racing before but I don't know to what extent they went other than I was told it had the hardened shaft, racing sprag and clutches. If anyone has installed a similar transbrake, I could sure use some help. Thanks
Old 10-27-2008, 06:10 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
there is no cover for the modulator. please post photos of what you have removed
trans brake installation is different from company to company... there may only be slight differences , but different.
Redneck Perf can not help? or will not? I am confused.
Old 10-27-2008, 06:51 PM
S10 Racer's Avatar
Here are a few pictures of what little I have done. Is this where the solenoid goes on a TH400? And if so, where would I run the wires out for the solenoid?
Thanks
Name:	TH400 Transbrake 001.jpg
ID:	33574   Click image for larger version
Name:	TH400 Transbrake 005.jpg
ID:	33575   Click image for larger version
Name:	TH400 Transbrake 004.jpg
ID:	33576   Click image for larger version
Name:	TH400 Transbrake 002.jpg
Old 10-27-2008, 08:03 PM
jakeshoe's Avatar
The t-brake solenoid goes in the modulator bore on the right (passenger) side of the trans facing outward near the front, around the same area as the dipstick hole.
The 4 bolt cover you have removed needs to be removed to take out the governor, as it's no longer needed.
You will usually remove the sealing rings from the 1-2 accumulator piston and block a passage in the case in this area.
You also need to remove a lip seal from the direct drum, and drill a bleed hole, as well as possibly installing some stiffer clutch return springs.
Not usually for the novice.
Old 10-27-2008, 08:17 PM
S10 Racer's Avatar
Ok, I found where I now think the solenoid goes. Is this the right location? I have the complete transbrake kit with springs, reverse valve body, etc. I have a few diagrams that show what o-rings to remove and where to drill the bleed hole along with a couple other diagrams but again, to understand them you have to have knowledge of the tranny. It says to remove the "over run" band and discard. I have no idea what or where this is located. Can someone help with this one too?
Thanks
Name:	TH400 Transbrake 008.jpg
T-400 transbrake BBCMudbogger Transmission - Rearend 0 06-17-2010 03:04 PM
th 400 transbrake??? or valve body 85 k5 mud truck Transmission - Rearend 2 07-15-2009 07:44 AM
turbo 400-79 trans am installation ssonny34@yahoo.com Transmission - Rearend 2 02-17-2009 11:08 PM
Transbrake installation questions S10 Racer Transmission - Rearend 2 11-02-2008 06:38 PM
Poncho 400 Distributor Installation trouble.. offroadin Engine 3 03-06-2005 04:09 AM
