need help with new engine i installed - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2004, 06:06 PM
jlraiders04's Avatar
New Member
Last journal entry: oo
i just put a new zz383 in my vette cant figure out whats wrong. i cant get a steady idle it races for a minute then returns to idle and repeats the same over and over. i think it may be bad gas or possibly the distributor if u have any clues please help id really appreciate it im kinda at my whits end
Old 06-13-2004, 06:09 PM
poncho62's Avatar
Wiki Edits: 5
Carburator needs work.....vacuum leak.......distributer....any number of things.
Old 06-13-2004, 06:11 PM
New Member
the distrb is the only
thing i didnt replace where would u look first
Old 06-13-2004, 07:09 PM
docvette's Avatar
Wiki Edits: 12
Bad Runnin...mon...
Doc here
Do you have a Q~Jet on it?
If so, Pull the Secondary Pulloff Vacuum line off and plug it.
If you have a Vacuum Advance, Pull the line there and plug it.
Run it and see if the racing stops...If so let me know we'll go from there.
Doc
Falcon Leader; Bandits at 2 o’clock!
Roger;
It’s only 1:30 now.
What’ll I do ‘til then?
Our bombs are smarter than
the average high school student.
At least they can find Bagdad on a map.
Old 06-13-2004, 11:50 PM
sbchevfreak's Avatar
Licenced Automotive Technician
if you've got a q-jet on it, check to make sure the secondary blades are fully closed.
