need help on parts selection - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-16-2002, 02:28 PM
Post need help on parts selection
hello fellow hotrodders i need help on deciding what parts would be best for my 350. i want a strong street motor that makes around 400 horsepower but is still driveable. i am thinkin of getting a set of World Products Sportsman 2 cast iron heads with 64cc chambers. with them i will have around 9.5:1 compression. i have a 750 quadrajet with a performer RPM spreadbore intake. the cam i thinkin of getting is a hydraulic roller cam from Crane Cams it has a 2500-6000 rpm powerband. the duration @.050" is 222/230 and gross lift is .509/.522" my camaro has a TH350 with 3.73 gears in the back.if i need a stall torque converter that is no problem. Do u think i will get what i want with this setup? if not what parts should i get?
Old 09-16-2002, 06:58 PM
NAIRB's Avatar
Post
This should work very well. This should be really driveable and with the Sportsman heads it will run on the top end .
Old 09-17-2002, 11:33 AM
Post
thanks alot NAIRB, what is the highest compression that you can run on pump gas with a set of cast iron heads,
