I have a 454 30 over bieng done up but i dont know anything about cams
what i want is a good sounding...kinda like the newer mustangs or the newer gto's...i was told to get lower duration... and a 600+lift... Any suggestions would be great . TY you all for ur time
You need to give more information, what vehicle, trans, gear ration, what are your expectations h.p. wise. What will the car be used for, daily driver? What other mods have been made to the motor, c.r.? What heads? Intake system? Exhaust?
68 gmc ...350 turbo...3.08...400+...casual driver,not daily...no other mods....049s with 226 int and 188exh...intake edelbrock 2.0... exhaust gonna do with dynoflow
With your combo I would defenitely go shorter duration, but I also wouldn't go .600" lift. I'd stick with something around 280-285 duration, and .530 lift.
The Crane 103072 would be a great choice for your combo if you want a hydraulic flat tappet camshaft. Or get the Summit marked version for less money, but the same cam. SUM-K03072.
Id go with something around 230@.050 on the intake side with a 112* lobe sep and ofcourse as much lift as possible...IMHO if you can adjust valves id go with a solid flat tappet as they perform better than a hdy flat tappet
Related Threads
Hot Rod Forum
2.2M posts
175.9K members
Since 2001
