Need help picking a dual carbs for my tunnel ram (sbc 383) - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2009, 12:46 AM
So currently I have the Weiand Tunnel from summit (it came on the car when I got it) http://www.summitracing.com/parts/CMB-03-0177/
This has two 4160 450cfm chokeless carbs with mechanical secondaries on them. I have been trying to get this tuned and just can't get it correct. I have been told to go to vac. secondary carbs w/ choke and things will run better. I was curious what you would recommend.
Details:
383
Wieland high tunnel ram
Cam: Duration 308/318, Lift .488/.510 (http://www.summitracing.com/parts/EDL-7102/)
64cc aluminum heads
I know that I could go with a different intake but I only drive this car every so often and it is more or less for cruising around town or up and down the valley and my Wife and I love the look of the ram :-) If you are curious the car is a 1930 Model A chopped and channeled. I would embed the image but my server isn't up right now. Thanks for any recommendations
Old 06-25-2009, 10:27 AM
lg1969's Avatar
Google "Tunnel Ram 406"
Just get a pair of 390cfm VS Holleys #8007. May cost a lot, but they do work very well for the street.
BTW: replace the top cover of the vacuum sec. diaphram housing with the cover that you connect a vacuum line between the two covers. This will give uniform secondary operation. It's not nessary to use both electric choke just use the rear choke for easy start-up. Leave the front choke wide open.
Old 06-25-2009, 11:58 AM
eric302's Avatar
Why be normal?
I've got a 50 Chev. with a 350, 480/230 cam, and Weiand tunnel ram, Edelbrock 500 cfm carbs. I know it's over carbed but it's what I had around. 411 gears and as much timing as i can put into it. Runs great on the street. Just my 2 cents worth
Old 06-25-2009, 12:19 PM
Holley
What can't you get them to do these should work fine if the are synced and adjusted properly,timing right no vacuum leaks. How about more info
Old 06-25-2009, 12:27 PM
racecar100's Avatar
Those Holley 660 is designed for tunnel ram
Old 06-25-2009, 03:39 PM
lg1969's Avatar
IMO: 450 and 660 cfm Holley are worthless carbs to use on the street. They will load up at idle. Your Gas mileage will suffer. It will backfire. It will be difficult to start when the motor is cold. Who is going to sit in the car feathering the gas pedal to warm the car? The cam and heads you have are fine. Just do me a little favor just get the Holley 390 and you will be fine. Your 383 will only see around 600 cfm at 6000 RPM. You do not need 900 or 1200 cfm on the motor unless your planning to shoot for 10,000 RPM.
Old 06-25-2009, 07:59 PM
Thanks for all the advice :-)
I have a TH350 with a 3500 stall right now with 355/373 gears I would have to double check.
I have the timing at 18 right now since I wasn't sure how much higher to go, 12 is about as low as it goes before it stalls.
The biggest frustration for me has been trying to dial it in to respond when I punch it. It seems to go fine with very light throttle but if I gas it at all (specially with vac advance on) it just stumbles then finally picks up and goes. Originally the first owner had the pink holley pump cams and those seemed to cause an over rich condition so I changed to the orange cams and gave that a try and now I can drive w/o stalling from idle but still not "balls" when you go. As far as available vacuum those carbs I have don't have any hookup other than ported. The previous owner tapped the intake for a vac. connection to the TH350 but other than that I have nowhere to hookup PCV (also which is leading me to want new carbs). The blow by w/ no hood leaves a nice fine mist after a long drive.
I think this weekend I will take some advice from F-BIRD'88 and see what I can get. In the meantime I will look at some of the 390cfm carbs recommended and see if I Can scrounge up the 700 for the carbs. I think the biggest reason for wanting the choke is upsetting all the neighbors trying to get the car warmed up :-) It doesn't get that warm up here in Seattle most of the time so I have to sit out there with it >1000 rpm for a few minutes and with more or less straight side pipes on it...
Old 06-25-2009, 09:06 PM
carbs
This is a big cam , it need gears ,what compression does it have?,what heads are on it, too little info.
Old 06-25-2009, 09:12 PM
It is running 10.1:1 compression as far as the make of the heads I would need to check with the previous owner. He had just finished building it when he lost his job and sold the car to make mortgage payments.
I attached a few pictures of the heads although I suppose it would be hard to tell without removing them.
ID:	38978   Click image for larger version
Old 06-26-2009, 12:57 AM
I just got home from work and e-mailed the previous owner to double check which brand the heads are (not really sure why I hadn't asked before). Based on visual inspection and knowing he got all the parts from Summit (he still had all the boxes in the garage when I bought the car) they are these:
http://www.summitracing.com/parts/SUM-162111/
Old 06-26-2009, 02:23 AM
Talk to this guy.. He does really know what he is talking about with the 390 carbs!!!! he has helped me out greatly on some info for a tunnel ram... two 390's is only 780 totall cfm, Not much more than what some guy's run with a single plane one carb setup... 390 IMO are the better setup for street use.
Old 06-26-2009, 09:56 AM
Thanks again for all the advice :-) I will take this and play with the car some more this weekend and shop around (Summit and Jegs I suppose) for the 390cfm carbs.
Also I checked with the previous owner and he can't get the make of the heads since the paper work is at home and he is on vacation but he said the block + heads came from Cylinder Head Specialties in Portland.
Tunnel Ram on 383 Stroker Nitromethane Engine 6 02-25-2011 09:06 PM
Tunnel ram info? Dons72camaro Engine 18 02-24-2006 12:37 AM
tunnel ram with 2-4's / lean 347mustang Engine 3 10-28-2005 05:39 PM
289 tunnel ram question flashover Engine 4 03-29-2003 06:09 PM
dual carbs for chevy 235 -EnVY- Engine 1 07-18-2002 10:22 AM
