need help picking rear gears - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-08-2012, 06:12 PM
ive recently put together a 355 with some 305 heads edlebrock rpm preformer cam intake and 750 carb its in a 2wd 86 chevy shortbox with a 700r4 tranny....im thinking i wanna change the rear gears but completely clueless on which way to go...i want fast take offs from the stop light and what not...the truck is basically a stop light chaser...hints tips tricks?
Old 10-08-2012, 06:18 PM
matts37chev's Avatar
I don't understand?
Last journal entry: this is only a test
need to know what size tires are you running on the rear?
Old 10-08-2012, 06:23 PM
they are 235 75 15s
Old 10-08-2012, 07:25 PM
big gear head's Avatar
High Performance Rear Ends
The 3.42 works well with the 3.06 first gear in the 700R4. The 3.73 would also be all right, but I wouldn''t go any farther than that.
switching rear gears and trans. what gears biohazard_81c10 Transmission - Rearend 2 04-05-2012 07:34 AM
********** rear gears hrm Transmission - Rearend 2 05-21-2011 08:56 PM
'52 Chevy 3600: Picking a rear-end Crakums_GT Transmission - Rearend 7 10-07-2010 09:15 AM
Tranny gears or rear gears? strummin67 Transmission - Rearend 4 06-12-2006 10:17 AM
I need help picking a rear end coop_01 Transmission - Rearend 4 02-08-2005 08:03 PM
