Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need help on picking the right converter
Old 03-19-2013, 07:15 AM
33Willys77's Avatar
33Willys77 33Willys77 is offline
You will get more responses if you list out all the specs -- Cam specs, carb(s), intake, car, weight (if you know it), tire size and so on. Generally, you would like to have your flash off at the start of your power range if you are looking for performance. If you called a converter place, they will ask the same questions.
