-   -   Need help on picking the right converter (http://www.hotrodders.com/forum/need-help-picking-right-converter-230907.html)
sscanrun 03-19-2013 12:28 AM
:sweat: Trying to pick out the right converter any help guys on brand and size of the converter, i have a big block street and strip but its a weekend driver with a th400 ,342 gears I have comp cams solid roller XR280R BBC
33Willys77 03-19-2013 07:15 AM
You will get more responses if you list out all the specs -- Cam specs, carb(s), intake, car, weight (if you know it), tire size and so on. Generally, you would like to have your flash off at the start of your power range if you are looking for performance. If you called a converter place, they will ask the same questions.
delawarebill 03-19-2013 07:46 AM
what's it in ????
u will get suggestions if we know what veh it's in.. most likely someone has the same or similar and can steer u...
Bonneville462 03-19-2013 12:08 PM
Chris ar CK Performance www.CKPerformance.com
or
Continental Converter.. Products
Have one made for your car, it makes a world of difference...
