Need help on picking the right converter - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2013, 11:28 PM
sscanrun's Avatar
Trying to pick out the right converter any help guys on brand and size of the converter, i have a big block street and strip but its a weekend driver with a th400 ,342 gears I have comp cams solid roller XR280R BBC
Old 03-19-2013, 06:15 AM
33Willys77's Avatar
You will get more responses if you list out all the specs -- Cam specs, carb(s), intake, car, weight (if you know it), tire size and so on. Generally, you would like to have your flash off at the start of your power range if you are looking for performance. If you called a converter place, they will ask the same questions.
Old 03-19-2013, 06:46 AM
delawarebill's Avatar
what's it in ????
u will get suggestions if we know what veh it's in.. most likely someone has the same or similar and can steer u...
Old 03-19-2013, 11:08 AM
Bonneville462's Avatar
Chris ar CK Performance www.CKPerformance.com
or
Continental Converter.. Products
Have one made for your car, it makes a world of difference...
T-350: do i need a stall converter or use stock converter tbrown8338 Transmission - Rearend 2 12-05-2012 03:32 PM
Need some help picking out a new Torque converter, TH350 xxllmm4 Transmission - Rearend 1 05-13-2012 07:00 AM
B&M Torkmaster 2400 rpm stall converter vs. stock torque converter??? zbhover Transmission - Rearend 2 11-02-2008 07:52 PM
picking a com beach_boy327 Introduce Yourself 1 03-07-2007 04:42 PM
Picking a color Wmarden Body - Exterior 6 10-23-2004 11:13 PM
