need help picking spark plugs - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-28-2012, 06:06 PM
I need help with the plugs have no clue where to start, heres the info.
350 chevy .030 over with forged manley 4 valve releif pistons, moly rings. speed pro .466 lift cam part no. cs1138r . the heads are 462 fuelie heads that have 2.02 intake and 1.6 exhaust . the intake is a eldebrock rpm performer hei distributor.
Old 05-29-2012, 03:59 PM
spark plugs
Look up the spark plug used in the year of your engine on advanceautoparts.com. If it says you use R45TS you use a colder plug R43TS for performance engines.
spark plugs fiddyfofoad Electrical 1 09-07-2009 11:35 AM
spark plugs deno Engine 1 04-03-2007 07:13 AM
spark plugs deno Engine 1 03-25-2007 08:55 AM
blazer has spark at coil and gas no spark at plugs ricksautorestoration Engine 29 02-15-2007 08:30 AM
spark plugs MIKE T Engine 0 02-14-2003 03:46 PM
